My DIF04 dishwasher had decided to stop working. The machine allows me to select a program as normal and when I close the door it beeps to signal the cycle beginning but alas nothing…..
Re: Indesit DIF04 fault. Cycle not starting no flashing ligh
That sadly doesn’t sound like an easy fix… I have just left it on for an hour, there is half inch of water on the bottom and then home has heated up to steaming point but has done nothing else. Does that still sound like the issue? I appreciate your help
