Indesit DIF04 tripping RCD
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit DIF04 tripping RCD
  • #64504
    killie99
    As title says, my first thought is the water pump is the most likely culprit. My gut feel is that it’s not worth fixing as it’s likely to end up at some point with the pcb burned out or a leak reading other reports on the machine. Can anyone concur on this?
    #357255
    washtronics
    Re: Indesit DIF04 tripping RCD
    the water pumps dont usually trip the rcd. check the heater and look on the pcb, if the pcb blows it is very obvious.
