Indesit DIF04B1UK
  • #103456
    Hollytree_Technical
    Hi all
    Does anyone know for definite what the resistance value of the dispenser solenoid should be on this dishwasher, I am currently measuring 5K2 ohm but was thinking/wondering if it should be lower.
    I have already tested the wiring in the door and had a visual look at the module but not finding any other faults I was looking at getting a new dispenser but as it only comes as part of the inner door I was hoping to confirm/deny my theory first.
    Thank you
    Jem
    #493228
    that about right
    if you assume resistance only and use ohms law
    current = Volts / resistance which give about 0.05 A
    then watts is volts * amps which gives 12
    now if you take inductance of the coil in as well it will probably be about 5 watts which is ok
