Indesit DIF04UK.R Dishwasher Flashing lights
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit DIF04UK.R Dishwasher Flashing lights
  • #92369
    Latham63
    Led`s 1+3 flash after machine has started & filled.
    It appears that after filling at around the time the wash motor should cut in, it then drains out with lights flashing.
    The fault code suggests a blocked filter. Checked fill & drain filters,no problem.Wash motor is worn.Continuity on heater & w.motor.
    Any ideas?
    #451087
    Hollytree_Technical
    Re: Indesit DIF04UK.R Dishwasher Flashing lights
    If the motor is worn then it may not turn when powered so I would start by changing that.
    Jem
