indesit DIS04 fills over night
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit DIS04 fills over night
  • #89801
    alro
    Hi gents this dishwasher fills overnight (but)with machine switched off when you close the door pump come on and emptys the water away suspect valve bypassing but why does the pump come on with the machine off at the switch or should i suspect the pcb
    or door leaved open at night so is it the pcb bringing the pump on if the door was leaved close ??? anyone help on this
    cheers alro
    #442595
    Re: indesit DIS04 fills over night
    If the base is flooded the pump will run even if the machine is switched off on the control panel, sounds like a faulty fill valve TBH.
    #442596
    alro
    but why should the pump only run just to empty the water out of the cavity then stop as thou its a timed pump out where as with water in base it would run untill you took the water out of the base?
    cheers for the reply iadom machine works fine just the problem of water in cavity in a morning when the door is leaved a jar i think i will try a new water valve cheers alro
    #442597
    The pressure switch could be sensing an overfill situation and pumping out until empty.
    #442598
    looks like a similar issue to this one:
    hotpoint-fdl570-filling-not-use-t92165.html
