indesit dishwasher dif16
Viewing 1 post (of 1 total)
  • #81487
    suedehead1
    hi,
    the machine wasnt filling solenoid on the water valve was open circuit. I replaced the solenoid and it filled then the second light from the left started flashing.
    The fault code appears to indicate the water turbine (flow meter) as being faulty. I replaced it tightened up the connections but it still wont work.
    It fills then starts to pump and fill at the same time then it fills again then the second light from the left flashes.
    Any help welcomed.
