Indesit dishwasher door problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit dishwasher door problem
  • #23212
    gingertomkins
    When I unload the Indesit DVG6221x dishwasher, the door is always trying to spring shut. Is there any way of stopping this happening?
    #197341
    Dave_Conway
    Re: Indesit dishwasher door problem
    Leave the lower basket out so it holds it down ? 😉
    #197342
    Trilobite
    I rather think that the original poster was enquiring about a possible adjustment that he may make to the door spring, to prevent the door springing closed…
    #197343
    This is a semi-integrated machine, so should have a door panel mounted on the front. When the machine was installed, the door should have been balanced by adjusting the the two screws in the top edge of the casing to ensure that the door stays flat with an empty bottom basket sat on it.
    If adjusting the spring tension cables, do each side evenly. From memory, anti-clockwise will reduce the spring tension, but one turn one each side at a a time to keep it all in balance.
    gingertomkins
    Thanks Penguin, thats solved the problem.
