Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit Dishwasher error code A05
- This topic has 13 replies, 4 voices, and was last updated 21 years, 8 months ago by
admin.
August 12, 2004 at 8:29 pm #6024
KeymasterMy Indesit Evolution DE73 dishwasher is failing with error code A05. Can anyone help me out with what this means, and if it’s something that can be easily fixed?
Many thanks in advance.
August 13, 2004 at 12:20 am #115144Penguin45
ParticipantPhoebe,
A05 is related to water level control. It can be a number of things, they are all buried under the machine. In all honesty, sending for an engineer is the best option.Either put up your post-code or have a look in the Directories section for someone in your post code area.
Penguin45.August 23, 2004 at 6:19 pm #115145admin
KeymasterRe: Indesit Dishwasher error code A05
I have the same machine and it comes up with A09 the cycle starts then stops after a few minutes and flashes A09, any ideas???
August 23, 2004 at 6:46 pm #115146Penguin45
ParticipantSome sort of circulation pump fault. Definitely time for professional help!
August 23, 2004 at 7:19 pm #115147admin
KeymasterRe: Indesit Dishwasher error code A09
thanks alot friend, where do I enter my post code to get help with this?
August 23, 2004 at 7:25 pm #115148Penguin45
ParticipantYou can check in “Directories” on the left, or put your post code up here and someone will pick up on it.
Good luck,
Penguin45.March 3, 2005 at 8:33 pm #115149admin
I have a message A08…..any ideas??
March 3, 2005 at 8:56 pm #115150clyde
ParticipantRe: Indesit Dishwasher error code A05
Its a problem with the wash motor – and needs a engineer to sort it out.
look in repairs@ for a local engineer; http://www.ukwhitegoods.co.uk/modules.p … whitegoodsClyde 8)
April 19, 2005 at 9:18 pm #115151admin
indesit DE 43 dishwasher error code A03?
April 19, 2005 at 9:22 pm #115152Penguin45
It’s to do with the temperature control circuit. Sensor failure, wiring failure, electronic board failure all possibilities.
Check Repairs@ or Directories for a repairer in your area.
If you are going to have a look yourself, pull the plug first. :plug:Regards,
Penguin45.April 20, 2005 at 6:32 pm #115153admin
Cheers for your help. At least I know where to start looking. 🙂
June 8, 2005 at 9:17 pm #115154admin
Did you managed to get his fixed?
August 24, 2005 at 9:15 pm #115155admin
5)a) Fault Code indications
Edited by Penguin45.
The information in this post was copyright to the Indesit Company and as such cannot be publicly posted.August 11, 2006 at 4:33 pm #115156raqueldoll
For error A05 try putting a powerful sink plug hole unblocker down your sink hole. It might not always work but it worked for me even tho my sink didn’t seem slow or blocked at all!
Raq
