Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › indesit dishwasher flashing light (fault code) non existing?
- This topic has 2 replies, 2 voices, and was last updated 20 years, 3 months ago by
TELL.
January 9, 2006 at 11:06 pm #14667
TELL
ParticipantHi everybody,
happy New Year to you all, back to work with a vengeance, 2 probs with m/c’s on 1st day back. other one to follow (Microwave).
1st problem is with an indesit DI 620 UK d/washer. Have checked through the fault code list, but cant identify this fault. (COD 37303510000, – S/n 404063647)fault code list’s a DI 61 range.
anyway the fourth light flashing on the r/h side from the left of the cluster, was flashing contineous (ECO Wash) no functions at all dead,shut down, reset programme set on a 2 wash heavy soil, filled, cold rinse, drained, then shut down again, but this time 3rd light on, out of the 4 (Quick Wash) now flashing. the DI 61 Range indicated to be a blockage/ drain pump fault. checked OK, proceeded to check heater, stats, air chambers, p/sw etc. all clear and have readings through the components.
Reset prog tried on Normal wash, filled washed drained the 1st rinse then shut down again as before, with the 3rd light flashing again.
sorry to be long winded but think’s i needed to give you info.
can anyone enlighten me on the problem?.
Ta TELL.January 9, 2006 at 11:38 pm #160386Dave_Conway
ParticipantRe: indesit dishwasher flashing light (fault code) non exist
Heating error by the look of it, this model has the Bit 100 module:
dishwasher fault codes with bit 100 timer(written on serial no)
led1=overflow water in base
led2=inlet valve
led3=hermister
led4=timeout heating
1+2timeout draining
2+3timeout filling
1+3filters blocked
1+4software error
2+4heater
3+4timer hardwareDave.
January 10, 2006 at 10:43 am #160387TELL
cheers dave for the info, but thats the one i had used. this d/washer does not have a timer , it has the prog selector left hand top of door. i also checked out the heating element its ok.. its as soon it finishes the drain from the 1st initial rinse, then ready to fill again. thats when it shuts down. flashing the 3 neon. the model is a DI 620.
i did get a reading through the thermistor, but forget it now. it is situated top r/h corner of dispenser, then plugs into pcb, in conrol panel.
TELL -
