You will need all the info on the door label as the PCB’s are configured for each model but all look virtually identical. The numbers on the PCB label along with the ones printed on the board seem to be relatively irrelevant in identifying the right one. It can only be done by model and date codes.
Don’t ya just love ’em?? :rolls:
I’ve taken to photographing all the labels I can find on machines and it’s often proved worthwhile. As here it seems, as I can look up the rest of the numbers on the door.
I have 37341400900 S/N 60607 1412
Also 19505578800
That seems to be all the numbers that might be relevent.
New board fitted and machine now working – albiet very expensive repair for such a new machine.
Thanks to Steve and Bob for your help.
Has anyone ever discovered which components cause these boards to fail to heat – or is it that those components which do fail are too small to be seen with the naked eye?!
