Indesit Dishwasher IDL500UK Fills for about 30/60 seconds then drain pump cuts in machine stops no flashing LEDs will not do anything unless you unplug for five minutes or so then it will do the same again.
Have checked pressure switch ok and hose to pressure switch not blocked.
Also had PCB out and looked for dry joints etc all ok there.
