IDL 40UK C S/N605228126
Heater and cut out stat ok. When i checked it on quick wash, at start of wash there is power through heater for about 10- 15 seconds and then the neutral path stops. If i open the door and and close it again the wash starts again and the same thing happens. Wires at bottom of door seems ok. Does this sound like a board fault? (checked board no dry joints etc).
What does the pressure switch on sump hose do? Is it anything to do with heater, ie heater cuts out due to low water level? Also how does it sense temp, could not find sensor?
Subs
