Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › indesit dl500 wash lights – but no action
- This topic has 10 replies, 3 voices, and was last updated 18 years, 7 months ago by
grepmonkey.
September 9, 2007 at 1:40 pm #30410
grepmonkey
ParticipantHi, the machine has the second light from the left lit – the wash light. I can hear a whirring but there is nothing happening. This goes on until you power off the machine. The filters dont look blocked, the machine is a couple of years old.
Can anyone advise what I can do next to find/fix the problem?
Cheers
GMSeptember 9, 2007 at 2:26 pm #227072Penguin45
ParticipantRe: indesit dl500 wash lights – but no action
Inlet valve failure.
Power off before taking any panel off.
September 9, 2007 at 3:31 pm #227073grepmonkey
Thanks Penguin45,
I am assuming that the inlet valve is the first electrical attachment to the incoming water tube. If this is the case I cant see any screws – how do you get it off?
thanks for your help
GMSeptember 9, 2007 at 4:07 pm #227074Penguin45
Looks like a slot in type – IIRC, you remove the upper of the two rear panels and it slides out.
September 9, 2007 at 5:58 pm #227075grepmonkey
Thanks Penguin45.
I have a white thing on the water inlet with a slot in card type iirc, so it must be it. Im assuming its the iirc that I need to replace and not the white plastic module or is it the whole lot?
Cheers
GM
September 9, 2007 at 10:44 pm #227076iadom
ModeratorRe: indesit dl500 wash lights – but no action
Err, http://tinyurl.com/2c8un3 I guess you don’t do the acronym thing then, 😉 The first one in the list is the one you are looking for. 8)
The inlet valve will look something like this http://tinyurl.com/yt82gm without the metal plate. IIRC 😀
PS. That model number does not match the current list from Indesit, do you mean an IDL500? You would have to check the inlet valve with a multimeter or meggar to find out if it was electrically faulty. Also worth checking that you actually have a water supply to the valve and that the filter in the valve is not clogged up.
September 10, 2007 at 10:30 am #227077grepmonkey
Cheers – I guess not I thought it was a type of pcb!
GM
September 15, 2007 at 2:08 pm #227078grepmonkey
is that inlet valve the same as the solenoid valve?
http://www.4indesit.co.uk/cgi-bin/produ … path=52688Thanks
GMSeptember 15, 2007 at 3:33 pm #227079iadom
The inlet valve is the solenoid valve. 🙂
September 22, 2007 at 1:26 pm #227080grepmonkey
I replaced the inlet valve, but I still have the same problem. Any other ideas?
GMSeptember 22, 2007 at 4:12 pm #227081iadom
Possibly engineer, Time, the electronic controls on Indesit machines are some of the least reliable on the market but we are getting into guesswork now.
