Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Indesit door has come off how do I put it back on
- This topic has 8 replies, 4 voices, and was last updated 20 years, 7 months ago by
admin.
August 22, 2005 at 12:26 pm #11478
Keymasterindesit model F1 E10 duel fuel cooker
The door just popped of and I cant find a way to put it back on?
Can anyone help please?
Thanks in advance
August 22, 2005 at 12:55 pm #145492Dave_Conway
ParticipantRe: Indesit door has come off how do I put it back on
There’s a “sticky” at the top of this forum that should help titled ” Removing oven door for cleaning” 🙂
August 22, 2005 at 6:58 pm #145493admin
KeymasterRe: Indesit door has come off how do I put it back on
I looked at them but the door aint the same, so its no good any more ideas?
August 22, 2005 at 7:26 pm #145494Martin
Anonymous wrote:I looked at them but the door aint the same, so its no good any more ideas?
We appreciate it isn’t the same but the principle is on those makes that allow full removal of the main oven door!
Are you saying that the door is broken? or has it simply got un-hooked from its removable fixing?
August 23, 2005 at 9:36 am #145495admin
The door hinge looks like this,i am havind difficulty putting all hinges into the framework of cooker
No it is not broken,just come apart lol
Is there a nack,i can get bottom hinges in ok or the top ones but not both at same time!
August 23, 2005 at 11:13 am #145496Dave_Conway
OK, put the hinge(s) back on the door then follow the instructions in the video, they are all much the same as Martin suggests.
Basically, you need to “lock” the hinges in the fully open position before putting back on to the cooker frame.
August 30, 2005 at 5:18 pm #145497admin
Thanks..
But there isn’t a way to lock the hinges,there is nothing but a basic hinge with no locking capabilities,they just flap aroud?😥
August 30, 2005 at 6:13 pm #145498Penguin45
Choochoo is quite right. The hinges are p/no C00031025 (There’s a lovely picture for Connect users) and there is no locking mechanism. I presume that the only way to do this is to manually overcome the spring on the upper arm by inserting them into the guides and levering the door down, whilst an extra pair of hands steers the bottom mounts into place.
Truly, a design masterpiece.
Good luck,
Penguin45.August 31, 2005 at 11:57 am #145499admin
Thanks a lot for helping,I’ve done it at last!!
What I did was to take the hinges out of the door as 2 seperate pieces,then struggle like a twat for half an hour on each hinge 👿 ,until they went in and were moving up and down normally.
Then I rebuilt the door around the hinges having to cut two slots in the bottom of the door to get it over the hinge assembly.
