Indesit dsr 15b1 uk
  • #91336
    evocado
    Hi.
    My dishwasher appears to be stuck mid cycle, some water is pooled and not drained. Initially the salt light was flashing, so I filled it up (which was unusual as I’d only recently topped it up). This failed to rectify the problem and upon moving the dishwasher I noticed a slight burnt electrical smell from the back.
    Also, not sure if this is relevant but if not it’s a bit coincidence: just noticed we also have a blocked drain in the garden where the outlet pipe leads to. I’m slightly sceptical that this could be contributing to the problem though as it’s only backing up slightly and is much lower than the dishwasher, naturally.
    Right now I have power but can’t get it to do anything. If you try to start a cycle the salt light will flash eventually.
    Any help greatly appreciated!
    #447779
    IncredibleMrT
    Re: Indesit dsr 15b1 uk
    Hi. Mine has started doing the exact same thing. Did you get yours sorted? What was it?
    I suspect the tub at the bottom of mine is full of water.
    Ta
