Indesit DV620WHUK semi integrated dishwasher. 37303480100. Serial no:- 412042318.
I’m not having a lot of luck with these PCB’s lately…….
I ordered C00143206 as Connect site showed 2 types fitted (serial number specific). C00143206 was shown as fitting machines before 61020 0000 and C00143222 as fitting after serial number 61020 0001.
So seeing as ’41’ usually comes before ’61’, I can’t understand why the C00143206 doesn’t fit. It refuses to reset and now won’t start a cycle. Obviously not the correct part. I retrieved the original PCB from the customer and found that none of the numbers on the C00143206 label match the original. Looking at C00143222 photo none of the numbers match either. 😕
How do you identify the correct PCB’s for these? And do any of the numbers on the labels mean anything? It’s an expensive lottery ATM…….:evil:
Can anyone help with this; what is the correct part number and also how can I correctly identify a BIT100 PCB for next time.
Thanks,
Steve.
