Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit DV620whuk pcb inisialize
- This topic has 11 replies, 3 voices, and was last updated 14 years, 4 months ago by
royston h.
December 7, 2011 at 9:48 am #66719
royston h
ParticipantI recently fitted a new timer card and it did not inisialise properly on my indesit dv620 all i have onnow is the red power light and when i make a setting it just beeps how do i reset and get it inisalised properly.
Many thanksDecember 7, 2011 at 10:46 am #364998iadom
ModeratorRe: Indesit DV620whuk pcb inisialize
What was the reason for changing the PCB?
There are at least two different PCB’s for this machine, have you got the correct one?
Have you still got the old PCB?
Full serial number & commercial code needed to verify correct part number.
December 7, 2011 at 12:34 pm #364999royston h
ParticipantRe: Indesit DV620whuk pcb inisialize
The water would not get hot everything else worked fine the new board is a C00143206 and it has a buzzer the old one which i still have has 21010324502 S1 ID:4014622 on it and had no buzzer.
December 7, 2011 at 2:49 pm #365000iadom
If your appliance serial number is 40505.0000 or less then that is the correct part.
If the serial number is 40505.0001 or higher then you have the wrong PCB.Did you test the heating element first? The solid bar type element inside the tub that yours has is far more reliable than the internal tube type but should still be tested first.
If there is a pre existing fault on the machine the PCB will not initialise, sometimes replacing the old PC running it to see if you get an error code and then refitting the new one can work.
December 8, 2011 at 9:57 am #365001royston h
Thanks for the reply i did check the heater element and it was fine i will try what you suggested not sure on the serial number as its fitted in machine at the minute i will check that next and fit the old board again, i will report back and thanks again
December 8, 2011 at 10:28 am #365002royston h
Just put the old board back in and it worked straight away but the water temp did not rise, the numbers on the new board are 21500933903 ID:1013721 is this correct?
December 8, 2011 at 10:35 am #365003iadom
iadom wrote:If your appliance serial number is 40505.0000 or less then that is the correct part.
Was this not clear? 😉 😀Look on the rating plate, usually down the side of the door.
December 8, 2011 at 10:40 am #365004royston h
50207 3058 thanks sorry must learn to read properly
December 8, 2011 at 10:46 am #365005iadom
You have been supplied with the wrong PCB, you need
C00109875.December 14, 2011 at 12:31 pm #365006royston h
Sent the other board back explained the problem and the board that i needed and i have been sent through a C00143211 VERSION S1 is this one ok before i unpack it all ?
thanksDecember 14, 2011 at 12:44 pm #365007Martin
royston h wrote:i have been sent through a C00143211 VERSION S1 is this one ok before i unpack it all ?
thanks
Yes! Yes! that is the latest replacement up-dated part number for the number Iadom gave you(C00109875)so it will be fine!😀
December 14, 2011 at 12:49 pm #365008royston h
Thank you very much 🙂
