Indesit DW IDL530UK2 4nd LED from left flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit DW IDL530UK2 4nd LED from left flashing
  • #32992
    Bernie
    Went to another one of these today, put it on program 4 quick wash went all the way through when it got to the forth LED it started to flash is this to say program has finished (no instruction book!) or is it a fault?
    Only it appears to works ok fills, heats, washes, drains.
    #237034
    Re: Indesit DW IDL530UK2 4nd LED from left flashing
    What was the reason for your visit?
    Fourth light flashing is a heater timeout error.
    Bernie
    Re: Indesit DW IDL530UK2 4th LED from left flashing
    Sorry but could you explain heater timeout error as the Fourth light did not start to flash until it got to the drying part of the program (Heated to temp then drained out)
    It heated both on the wash and the drying; I sat with both side panels and top off got very hot both times.
    My question was should the 4th LED from left flash at the end to say program has finished?
    #237036
    I refer you to my first post, if everything is working, why did the customer call you out?
    It might help to point us in the right direction.
    Bernie
    #237038
    Just because it gets hot doesn’t mean that the pcb knows it’s getting hot. I’ve had a lot of thermistor failures on these.
    Bernie
    Will order a thermistor and give that a try.
    The only part I can see on Partfinder is T/STAT SAFETY 78C NC part No. C00041086 is that correct, if not would you know part number?
    Did find on another INDESIT IDL530 post about a module with ntc attached part No.C00143209 is that it?
    Thanks for all the help and info.
    #237040
    Yup, correct number for module & thermistor.
    hotpnt
    hi, the wash light will flash at end of programme, its only a fault indicator if you cannot then clear it & run another programme,
