Hi Folks,
I have the above cooker (Indesit FI31KBIX GB) which last night seemed to trip the consumer unit a couple of times, the penny didn’t drop at first until I noticed the oven hadn’t warmed up properly in the twenty minutes I’d left it running as I was making a pie!
Turning it off and on again, the fan then kicked in straight away and it was off like a good ‘un, and upon searching the net and using a bit of common, my brain tells me that’s going to be the element, not the fan, as the fan kicked in once the element had a ‘good circuit’ and power was flowing?
I’ve tracked some down on eBay for about £11, was thinking of taking the cover off and having a nosey to sort of confirm first, should I be able to see some fairly obvious signs of ‘damage’ and is my thinking/theory about the fan correct?
Thanks in advance, Dave.
