Indesit Electric Oven Faulty
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Indesit Electric Oven Faulty
  • #101779
    Bhavick35
    I’ve got a Indesit electric oven, am not sure what the model is I’ve attached some pictures in the links below which hopefully show this.
    https://ibb.co/ZYDdLp2
    https://ibb.co/VxdjwyQ
    Yesterday i was using the oven and top left heating element made a kind of popping sound and then suddenly stopped working. The rest are working it’s just the left one can anyone help or advise on what this might be please?
    #486022
    ok
    you state in the title you have an indesit oven but the pictures are of both the oven and the hob
    Which one is faulty ?
    tubafan
    It’ll either be the element or more likely the switch for it that has failed.
    I believe the switch will be this one – https://parts.indesit.co.uk/cooker-energy-regulator-j00618693/p?fromBOM=true
    #486024
    Bhavick35
    electrofix wrote: ok
    Hi Dave,
    Sorry I should of mentioned it’s the oven hob that is faulty, its’ the front left one that isn’t working. It’s weird because it works on all the other temperature settings except number 3 and it tripped a fuse in my fuse box when it started to become faulty. Haven’t used it since. I’ve had a quick look on the indesit website and this replacement heating element is available for it, please see link below:
    https://parts.indesit.co.uk/1800w-element-200mm-j00157741/p?fromBOM=true
    It looks like am going to have to try and fix this myself as i haven’t really got the money to pay the call out charge for someone at indesit to come and have a look at it. If anyone has any experience of replacing one of these is it difficult to do for a newbie?
    #486025
    Bhavick35
    tubafan wrote:It’ll either be the element or more likely the switch for it that has failed.
    I believe the switch will be this one – https://parts.indesit.co.uk/cooker-e…p?fromBOM=true
    Taking in to consideration the left front hob works on all the other heat settings except number 3 do you think it would still be the switch or more then likely the heating element?
    #486026
    as long as the ring lights up fully on full power its got to be the switch
    if you strip it you will find faulty contacts
