INDESIT EVOLUTION Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › INDESIT EVOLUTION This topic has 3 replies, 4 voices, and was last updated 20 years, 6 months ago by razor. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts September 21, 2005 at 8:53 pm #12104 razorParticipant Got error code F12 , a know this means LCD Display module and main module not communicating correctly anybody help in what am looking for thats causing the fault . Is it the lcd thats faulty or module or can it be wiring thanks all 🙂 September 21, 2005 at 9:05 pm #147906 Dave_ConwayParticipant Re: INDESIT EVOLUTION Poor connections on the edge connectors normally razor 🙂 Dave. September 22, 2005 at 3:26 am #147907 andy2Participant Re: INDESIT EVOLUTION Yep, Daves blob on. Easiest – try slipping the connectors on and off a few times, failing that – carefully clean up the tracks at both ends and re-spring the idc connector pins with a small needle to tighten the fit. If this does not work then you may have a dodgy eeprom (corrupted data) on the display module. They should have renamed the eeprom’s on these machines MMMD’s (Merloni money making device) Andy September 23, 2005 at 6:47 pm #147908 Tony_EMWParticipant Re: INDESIT EVOLUTION We diagnose & reprogram these Evolution parts. Send the main board & display for test/repair same day. F12 often means memory messed up both on the board AND display Tony http://www.emwelec.co.uk Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
