indesit evolution we16 error code -h20
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit evolution we16 error code -h20
  • #11406
    machine would’nt drain and showed error code f05 so i drained it by cleaning out the filter and moving a ball ike object around which was inside the pipe above the filter now the machine just fills and drains at the same time and shows -h20 any idea what this means? and what i can do?
    #145264
    Re: indesit evolution we16 error code -h20
    You’ve somehow flooded the water level system to show that error (H20 = chemical formula for water)….Are you sure you put the ball-valve back correctly??
    #145265
    andy2
    H20 is a fill timeout error (has not filled in the designated time)
    If the machine is emptying whilst filling chances are that you drain hose is too low down. Make sure that the drain hose has a point that is at least 2 – 3 inches higher than the highest water level in the machine.
    Andy
