Indesit f/f
  • #93628
    kaibart
    I’m not the best on refrigeration but am learning slowly just look for some advice before I go to look at this indesit fridge freezer model number inc625aiuk both fridge and freezer are not getting cold. Am I right in thinking this is more than likely a systems fault? And if not what should I check as always tia kai
    #455048
    Re: Indesit f/f
    cant see that model even on google. Are you sure its correct
    you say both sides are not getting cold but you don’t say if compressor is running. If its not running it could be stats and board fault as you no doubt realise
    kaibart
    Re: Indesit f/f
    Hi Dave model number is correct it’s a built in not a frost free here is number listed on connect this is the only info I’ve had off customer hoping not to pull it out if not needed 😯
    #455050
    Re: Indesit f/f
    well that makes it more confusing
    original number you listed was inc625aiuk
    number underlined in list is inc310gd
    but can see inc265AIUK
    assume that one is correct and you transposed numbers
    seems like simple stat controls on this one if its correct
    will pm it
    if its still wrong get me the F0 number
