Indesit fan assisted single oven DFW 5530
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit fan assisted single oven DFW 5530
  • #96930
    rocker
    The oven is overheating stat light not going out…I fitted new stat still the same fault…any idea what may be causing this as I don’t want to spend hours trying to trace the fault or interchanging parts . cheers ..john
    #465435
    that’s mad
    wonder if someone else has been playing with the wiring
    if you pull one wire off the stat does the light go out
    assume you know its overheating and not just a light problem
    wilf
    isnt this a convection oven with fan assistance? if it is have you got continuity through both top and bottom element? bottom element my guess.
    wilf
    #465437
    suedehead1
    I had the same problem there was an earth leakage at the base element
    #465438
    rocker
    Cheers guys for all your replies…John
