Indesit FD20 Built-In Double Oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Indesit FD20 Built-In Double Oven
  • #75400
    womble
    Hi All
    I have had the above oven for 5 years now, a few years back the grill element packed up, which I purchased from you guys and with little drama changed.
    Now the problem I’ve got is the top oven doesn’t reach temperature, the grill works fine still, but the oven barely gets warm.
    Any pointers on what to test would be gladly received
    Many Thanks in advance
    Cheers
    Lawrence
    #394804
    nigegt
    Re: Indesit FD20 Built-In Double Oven
    Sounds like the base element in the top oven has failed so i would look there first.
    Nige
    #394805
    womble
    OK Cheers, will do
    #394806
    womble
    OK. The grill works perfectly, but the oven doesn’t reach full temperature. The floor of the oven gets hot, too hot to touch but only reaches 140c (although thermometer is a tad iffy) DO you think it could be the thermostat or the base element? And, is there anyway of testing them before I fork out for one ones?
    Cheers in advance
    Lawrence
