Simply needs a stat…tried the original part as quoted by Connect and Masterpart but both these replacements cut out far too low (in excess of 80o at the top end 😯 )
Has anyone else had this problem and if so what alternative stat did you use…it’s a ‘D’ shaft, two-screw mount type?
