Indesit FIE36KB1XGB no heat
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Indesit FIE36KB1XGB no heat
  • #45131
    damiant
    Great forum
    I wonder if you can help i have an Indesit FIE36KB1XGB fan oven .
    When i turned the oven on last night only the fan and light work. It doesnt matter if you select Oven or Grill, only these features work.
    I have made sure it is on manual and checked all connections and still no heat on the grill or oven when they are selected.
    Could this be the oven thermostat or both elements have burnt out at the same time. The oven was used the night before with no apparent problems .
    The front panel light for the oven/grill is illuminated when you select grill/oven .
    Hope you can give me some pointers on this one .
    Damian T
    #283758
    wards
    Re: Indesit FIE36KB1XGB no heat
    Sounds like switch faulty to me.cannot see both elements going together HTH 🙂
    #283759
    damiant
    I agree its highly unlikely that both elements would have gone pop, but dont know about the thermostat
    Guess ill have to test the switch and thermostat
    Regards
    Damian
