Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit Flashing LED HELP required PLEASE!!!!
- This topic has 5 replies, 2 voices, and was last updated 19 years, 10 months ago by
rwatt.
May 29, 2006 at 3:19 pm #18131
rwatt
ParticipantHi
I have an Indesit D40 dishwasher. A piece of glass found its way into the pump which i have now cleared. The problem is now when i switch it on it beeps a few times goes through an empty cycle the the second LED keeps flashing……
Any help would be great THANKS!!!
May 29, 2006 at 3:52 pm #177833Penguin45
ParticipantRe: Indesit Flasing LED HELP required PLEASE!!!!
Fill problem – you haven’t pulled a wire off the inlet valve whilst underneath, have you? Also, water not turned back on or fill hose kinked/ trapped when machine pushed back are common ones.
Power off if checking underneath again…..
Penguin45.May 29, 2006 at 7:54 pm #177834rwatt
Possible you would’nt happen to have a wireing diagram or point me in the right direction to get one would you??
May 29, 2006 at 8:53 pm #177835rwatt
Now have 2 flashing LED’s 1st two…. Any ideas?
May 29, 2006 at 11:19 pm #177836Penguin45
Oh, what fun we’re having…… this code is not draining in the time allowed. It suggests some sort of problem with the water level control system – did you turn the machine on its side when sorting the pump blockage? If so, water may have worked its way into the pressure tubes or even the level switch itself – all sorts of strange things can happen after that.
I suspect we may be approaching the point where pro help may be the best option………
Not to mention the endemic problem with heater failures, which throws up all sorts of weird codes.
Sorry, it’s a technically complex machine, with quite a few foibles – logic is not always enough. Tech support is non-existant, so either work through these points one by one, or get some pro help.
Penguin45.May 31, 2006 at 8:19 pm #177837rwatt
THanks for your help dont really want to go down the line of calling out a tech if its a simple fault. It now seems to be stuck in an empty mode. I have checked and there is no water stored anywhere in machine bah prob just chuck it out……
