indesit flashing/timer going round
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries indesit flashing/timer going round
  • #5689
    PINKY
    Hi chaps, I know these flash codes are supposed to be somewhere on this site but i’m buggered if i can find them. I have an indesit timer going round and flashing 9 times. All components including brushes are ok. Does anyone know what the 9 flashes correspond to? cheers
    #113103
    lotusray
    Re: indesit flashing/timer going round
    hi 9 flashes indicates set up error if it has had a new pcb check eprom fitted correctly failing that eprom required plus board probably
    post model no i will supply part nos for u
    i will post all fault codes when i can get scanner 2 work
    #113104
    Dave_Conway
    Lotusray, do these fault codes below, which are displayed on the lcd type(already in “known error codes”) correspond to the number of flashes on the neon type as well ?
    F01 Short Circuit-Motor Triac
    F02 Motor jammed or tachogenerator detached
    F03 Temp probe o/c or s/c
    F04 Pressure switch jammed on reset
    F05 Pressure switch jammed on trip
    F06 Programme selector management error
    F07 Heater relay stuck
    F08 Heater relay cannott be activated
    F09 Incompatable eeprom
    F10 Pressure switch not sensing correctly
    F11 Pump cannot be be activated.
    F12 LCD Display module and main module not communicating
    #113105
    lotusray
    they sure do 😆
    #113106
    Dave_Conway
    Yay, thanks 😀
    I’ll edit my post then 😉
    #113107
    AMS
    Lotusray,
    As you seem to be the guy in the know, do you know what F15 on a WDE12 is?
    lotusray
    f15 = check pressure switch check connectorspcb and p[ressure switch but favourite will be drier relays on pcb stuck try giving it a knock see if it frees relay if so i think u can get relays from cpc
    #113109
    Lotusray,
    Could I ask you please to post the Indesit/Ariston Washer/Dryer error codes for us as well 🙂
    Thanks 😉
    AMS
    Thanks very much for that, Lotusray
    #113111
    PINKY wrote:I have an indesit timer going round and flashing 9 times.
    …I know the feeling mate..!! 😆
    Dave_Conway
    :rotfl: LMAO !
    You did it then 😀
    #113113
    cornwell40
    Flashing 9 times.
    An Indesquit W123S only 13 months old!!!!!
    “No Mrs, The S is for sh*te not silver”.
    Tony C
    #113114
    cornwell40 wrote:“No Mrs, The S is for sh*te not silver”.
    :rotfl:
