Indesit FM20KC Element
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Indesit FM20KC Element
  • #19256
    Simon46
    Does this have a conventional oven with fan assist or fan oven element.
    Oven tripping RCD. Is there qualtex equivalent? C00081590 C00081591 are elements listed.
    Regards
    Simon
    #182409
    Re: Indesit FM20KC Element
    Simon46 wrote:Is there qualtex equivalent?
    I don’t see anything like them in the Qualtex catalogue? This oven has both a bottom element and grill element and uses fan assistance. 😉
    #182410
    Bryan
    This oven doesn`t have a fan element but just uses top and bottom elements and a fan motor to circulate heat.
    Before ordering any expensive element I`d check the bottom element as I`ve had a couple on this model where the terminals have shorted against the rear cover. There is hardly any clearance between the cover and the uninsulated terminals to the lower element 😯 .
    From memory I simply bent the terminals a little and fitted insulated covers to the connectors 😉
    Bryan
