Indesit Fridge Freezer
Home Forums Public Support Forums Spare Parts Help Indesit Fridge Freezer
  • #97407
    charles crellin
    Need a bit of help with some part numbers for a fridge thermostat for my Indesit BAN 12 NF S UK, also any wiring diagrams / parts list would be greatly appreciated, thanks in advance.
    #467534
    can be done but to bring up correct info we need all the numbers off the plate as there are at least 10 variants with same model number
    you also say you want a fridge thermostat. As most electronic controlled units use sensors and not thermostats we need to know what you mean. If it is the sensor then its foamed in on a lot of units and cant be changed.
    charles crellin
    Trying to upload a picture of the plate but it will not let me, thanks for getting back to me, I fear you are right it is a sensor refrigerator, I can tell you a bit of the problem though, the control inside the fridge its self, when i turn the temperature higher nothing happens, it doesn’t kick the compressor in or the fan when I close the door, the freezer control, if I turn that up higher, that seems to work, it is a new one to me, its something I had to grab quickly.
    #467536
    you can host the photo on another site and just post a public link on here
    its not like the old type stats dont expect instant action
    you need to check the damper in the fridge
    also check the knob is actually turning the pot on the pcb. its very thin plastic and i have seen the odd one break. While your in there you can check for bad joints
    charles crellin
    Thank you, will start pulling it apart give it a good check over, I think at the worst it will be a new damper or very worse a new board, thanks for getting back to me and the help, very much appreciated.
    #467539
    charles crellin
    Think I got it now thank you for your help, the fridge thermostat has no electrical connection to the thermostat PCB, so no matter how much I adjust it it wont bring on the compressor or fan. so it is not a fault, it is how it is made.
    #467540
    its all about temperatures
    if the temps are within spec why worry
    charles crellin
    Absolutely true, using a fridge thermometer it is getting down to around 5, which is within range for mine and my sons insulin storage, plus good for the milk and food.
