Indesit FV 10K (IX GB) – Instruction Manual or FacePlate …
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Indesit FV 10K (IX GB) – Instruction Manual or FacePlate …
  • #22347
    mgdew
    Just moved into a new house, and found this built in Indesit Oven (Fan assisted with grill) has absolutely NO print left on the faceplate, so I have no idea what settings the knobs are, or what temperature I am setting it too.
    I have tried searching online for images or instruction manuals etc but to no avail, has anyone got an image or an instruction manual for this model, would be exceptionally grateful.
    Cheers
    Re: Indesit FV 10K (IX GB) – Instruction Manual or FacePlate
    Control panel – p/no C00094110
    User manual – p/no C00094109
    An email to spares@ukwhitegoods.co.uk for prices and ordering.
    alanjam
    Hi Martin,
    We are in a similar position to you except that we have the instruction manual. Unfortunately the illustration is too small to make out the numbers so it’s not of much value.
    Have you sought a price on a replacement panel? What we really need to a stick on dial.
    Like you I couldn’t find info on the net. Will remember this when we ultimately replace the oven.
    Cheers Alan
    #194583
    purpletiger
    Hi.. Would of thought you’d worked it out by now, but if not here goes.. the dial on the left is for the different settings of the oven. i’m going to go round clockwise. the 1st setting is for your oven light, the 2nd for thaw, 3rd for fan oven, 4th for the grill (small), 5th for double grill, 6th for ventilated double grill. The dial on the right is temperature, i think it starts at 80c and goes up to 220c.. good luck!!.
    #194584
    Washman
    If you look at the date of the other posts above , you will see that they are 2 years old.
    Mike
    #194585
    helo_75
    14 months, if your going to split hairs
    #194586
    purpletiger wrote:Hi.. Would of thought you’d worked it out by now, but if not here goes..
    To be fair to purpletiger, reading the above suggests that they were well aware of the elapsed time but nevertheless tried to be helpful. 😉
