Hi all
I have been to look at the above machine and can see no dodgy connections or broken/damaged wires and it has worked perfectly every time I have tried it (apparently it only fails once every 3 weeks or so). When it fails it will still run the motor and do everything but heat, the customer then has to wait about 3 days before it will work again. I have checked the filters, condenser and water tank (Customer reckons that they clean/empty before each use – It looks clean as well).
I am wondering whether a sticky float switch would cause this? – Didn’t have time to rig it and it is in an awkward to get to position so can’t test it when live.
Does any one have a service manual for this machine please or any other ideas as to what could be going wrong?
Thank you
Jem
