Indesit IDC 75 Condenser Dryer Blowing House Fuse
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit IDC 75 Condenser Dryer Blowing House Fuse
  • #59809
    leew
    Alrite guys, posting this on behalf of a friend of mine.
    They have the above mentioned dryer and every time they try to start it up it blows the main house fuse, i realise it could be one hundred and one things but is there anything nice and simple for them to check for?
    Ta.
    #339662
    gandh1
    Re: Indesit IDC 75 Condenser Dryer Blowing House Fuse
    moulded plug #1
    element #2
    water in base/spraying on element/motor #3
    pump #4
    pcb #5
    #339663
    leew
    gandh1 wrote:moulded plug #1
    element #2
    pump #4
    pcb #5
    Thank, you will ask them to check that little lot out.
    I do believe they have replaced the moulded plug and that made no difference.
    Do you know if they haven’t cleaned the Condenser box & area that that could cause it due to moisture/damp build up possibly?
    #339664
    leew
    Fixed 😀
    Thanks gandh1.
    #339665
    rickyc785
    leew wrote:Fixed 😀
    Thanks gandh1.
    How did they fix the problem leew? I have the exact same issue. There does seem to be water in the drum but the tray is empty?
    I’ve called for an engineer but they are not coming till a week on Tuesday !! Any help would be appreciated.
    Many Thanks
