Any help please on getting belt over the jocky pulley on this condenser dryer tryed levering it with a big screw driver wont go over the pulley thanks fasetester
this looks like an old one so they are not too bad
remove fan cover and front fan
remove the bolt on the pulley nearest to you
loosen the other bolt just enough so you can unhook the pulley and flip it over
put belt over the pulley and then use yje pulley and a lever to tention it and hook it into place, spin drum by hand to centralise
nip up farthest screw and put the nearest one back in
Thanks dave had to fit New jockey pulley one the holes did not line up right then when i was trying to fit the belt the belt broke should i streach New belt before fitting as i could not get thè old belt near the pulley thanks fasetester
Best way to get the belt over the pulley is not to slack it off or remove one of the bolts. Just get any washing machine belt, put it around back of dryer belt and pull it over pulley. Easy job done, and no chance of braking pulley.
