Indesit idc 85 uk
  • #100641
    fasetester
    Repaired this dryer fitted New jockey pulley cleaned out tested Everything seemed to be OK got call today to say no water in drawer water leaking on floor .
    what be most likely problem blockage what most quickest way to check that pump is working thanks fasetester
    #481581
    take lid off and remove draw
    start dryer and pour water into the draw container and it will flow down return tube and see if it pumps it up
    fasetester
    Thanks Dave for your reply the said water coming out of vent at the front in your experience would you say blockage at back of condenser fasetester
    #481583
    does sound like either the pump has failed or more likely the duct from condenser to water pump is blocked
    fasetester
    Went back to check dryer cleaned condenser cleaned channel at the back took of pump cleaned all out was full of sodden fluff .
    checked pump for broken propeller all OK pump running OK float in bad shape a bad float should not stop pump sending water to drawer .
    checked hoses and jet at back drawer when running dryer with side panel off water spitting out of condenser end of program no water in drawer puddle on the floor thanks fasetester
