Indesit IDC75 Tripping RCD
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Indesit IDC75 Tripping RCD
  • #80632
    gtimkim
    I have an Indesit condenser dryer that keeps tripping the Newly wired into the wiring, RCD. The tumble dryer is about a year old with light use and regular cleans of both filters. It will work fine on another ring main but not the RCD protected one, tripping it all within seconds. Should I disconnect and take panels off to see any obvious faults? I can take it into work and get one of the leckies to have a look for me but I’m happy enough to have a look myself first. Any advice would be appreciated.
    Thanks,
    Tim
    #413537
    Re: Indesit IDC75 Tripping RCD
    If it is only tripping the rcd then it is almost certain that you will not be able to ‘see’ anything. Only an insulation test with a megger or suitable multimeter would identify the fault.
    Almost always caused by dampness getting onto the heating element at the rear. Although you say you clean the filters this is mainly caused by a failure to remove and completely clean the condensor unit. A garden hose or pressure washer is the best way to achieve this, you also need to reach right back into the condenser housing and clear any gunge from the channel that runs along the back.
    In most cases the heating element can be simply dried out by carefully removing the back panel and blasting the element with a hair dryer for ten minutes or so.
