INDESIT IDC75 UK BELT TENSION PULLEY WHEEL
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum INDESIT IDC75 UK BELT TENSION PULLEY WHEEL
  • #84818
    number9
    I’ve taken the covers off my machine and ordered another tension pulley wheel as it had failed.
    I would appreciate some help as to how I can remove old/fit new part. I don’t know how to remove the fan cover (I think that’s what it is) to give myself some access to remove the bolts. In its orginal postion there is very little space to work with.
    many thanks,
    Steve.
    #426909
    Re: INDESIT IDC75 UK BELT TENSION PULLEY WHEEL
    fan cover is just clicked in. you will need to prise where it locks but it should slip out
    after its out use pliers to remove the clip from the fan and ease it off
    you can then access bolts and remove pulley
    to replace only partly put in the furthest bolt, put belt over pulley and use it asd a lever to tention belt. then put the second bolt in and tighten both. spin drum by hand to straightan belt
    fan cover can be tricky to get back
