Indesit IDC85 Water Puddle
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Indesit IDC85 Water Puddle
  • #79713
    funmonkey100
    I have a Indesit IDC85 condenser tumble dryer and when i am drying clothes i have noticed under the heater unit there is foam near the fan and its soaking wet and dripping water from it. Everything is clean draws filters and the pump is working ok. Any one know why this could be happening. i also took the back off and nothing unusual.
    its dripping from the foam part of this picture you can see.
    #410303
    Andy jones
    Re: Indesit IDC85 Water Puddle
    Take out condenser and clean it thoroughly also feel right at the back and remove any gungy fluff
    #410304
    funmonkey100
    will try that i did clean the condenser and got to the back with a cloth but will try again and see if that helps, i will try and see if i can clean all the way to the fan assembly to the back right.
    #410305
    funmonkey100 wrote:will try that i did clean the condenser and got to the back with a cloth but will try again and see if that helps, i will try and see if i can clean all the way to the fan assembly to the back right.
    You cannot reach the fan assembly that way.
    Either carefully lie the machine on it’s back or lie down on the floor and feel right into the back of the condenser chamber. Right along the back is a drain channel that gets clogged with gunge, you need to run your fingers along this channel and scrape out any detritus. There is a small drain hole that leads from this channel into the pump/float chamber at the back, this can also get blocked and can be cleaned from inside the float chamber at the rear.
    #410306
    funmonkey100
    I have cleaned it all up but there was nothing in there blocking the drainage hole. I think steam is getting in the fan side and dripping down but not sure. In the heater fan housing.
    #410307
    adv
    did you find out what was wrong with this , as i have one doing the same ?
