Indesit IDC8T3 Timer
  • #99543
    Hi everyone.
    managed to get a free indesit IDC8T3 dryer.
    The reason it was free was because the previous owner fitted a replacement belt, but in their wisdom they disconnected all the wires from the timer without taking any pictures. As you have already guessed they couldn’t remember where any of them went. After having several attempts and blowing various fuses they decided to get rid of it.
    Unfortunately out of all the tumble dryers I own I don’t have another idc8t3 to copy. is the anyone who maybe able to assist me.
    Any help would be greatly appreciated. Otherwise I’ll have to wait for another one to come up for sale.
    Thanks in advance.
    Daniel
    #476794
    there are 2 different timers fitted to these units so would need to know the make on the timer
    Hi Dave. Thanks for the reply .
    I’ll have to dig it out from the back of the dead appliance shed (it’s no mean feat, believe me)
    As soon as I know the info I’ll get back to you.
    #476796
    Not sure if this is any help but it’s two photos I actually have on my phone. In the meantime I’ll get the others. For some reason I can’t upload pictures on here so I’ve attached a photo link to them. https://linksharing.samsungcloud.com/nGUx6uMXl8Sd
    #476797
    looks like it may be this one
    Thanks for the reply Dave, the diagram was spot on. The door interlock contacts were also welded together, so I could load the dryer whilst it’s running thanks for the help. 🙂
    #476799
    B5 should be correct
    andyjawa
    NOTE. To save anymore screw ups with changing belts from the front of the machine it is actually easier and less risky to change a belt ( regular occurrance on these ) from the rear of the machine. You really want to change the rear bearing at the same time anyway.
    #476801
    andyjawa wrote:NOTE. To save anymore screw ups with changing belts from the front of the machine it is actually easier and less risky to change a belt ( regular occurrance on these ) from the rear of the machine. You really want to change the rear bearing at the same time anyway.
    agree do all of them that way
    you can often just sneak the belt down the back after removing most of the screws without a complete strip down
    andrew heggie
    I have the same problem has anyone got a diagram of the wires please
    #476803
    andrew heggie wrote:I have the same problem has anyone got a diagram of the wires please
    like the one above ?
    andrew heggie
    Yes mate I can not get the phot
    #476805
    you wont get it as such but you can do a screen dump , edit and print it
    we dont know which timer is in yours as there are 2 makes hotpoint / indesit use
    is your timer invensys ?
    andrew heggie
    It’s an ind
    #476807
    andrew heggie
    It’s a indesit mate
