Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Indesit idc8t3b motor not turning
- This topic has 5 replies, 3 voices, and was last updated 3 years, 9 months ago by
Timmy1362.
June 11, 2022 at 3:57 pm #100905
Timmy1362
ParticipantAfter replacing a snapped belt caused by a zipper getting stuck in the drum and jamming it, on checking the drum turns freely and switching back on to test I encountered a rumbling noise and the motor not turning. Common wisdom is that this is caused by capacitor failure, so I have replaced the capacitor as well. But the problem persists. Should I assume that the motor has burnt out after spinning under no load?
June 12, 2022 at 8:19 am #482665iadom
ModeratorA capacitor failure usually leads to a humming noise not a rumbling one. When you say the motor is not turning do you mean the drum is not turning. The drum should move when turned by hand but not freely, there should be some resistance when trying to push it round. I am wondering if you have got the belt back on correctly? These motors very rarely burnt out and you would be able to smell a burnt out motor.
June 12, 2022 at 9:42 am #482666Timmy1362
ParticipantHi iadom, thanks for your reply.
The belt is correctly seated around the drum and pulley and the drum turns with a little resistance. I have removed the belt to test whether the motor works when not connected to the belt, but it doesn’t turn. The noise is definitely a grumbling rather than a hum. There has been no trace of any burning smell. The noise doesn’t seem to be coming from the motor but from the other side of the machine and I wonder if it’s just the normal sound coming from the heater or condenser that wouldn’t normally be noticed over the sound of the motor and drum?June 12, 2022 at 9:51 am #482667Timmy1362
ParticipantUpdate: I am a massive IDIOT.
I have just noticed that when removing the front panel I had dislodged one of the connections to the timer dial. I’m so f…g embarrassed right now. Please accept my apologies for wasting your time.
*crawls away, hides*Tim.
June 12, 2022 at 10:15 am #482668iadom
ModeratorThe noise you can hear is probably the drain pump.
June 12, 2022 at 11:29 am #482669electrofix
ModeratorTimmy1362 wrote:Update: I am a massive IDIOT.
we have all done things like that lol
