Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Indesit IDCE8450 BH Drier fault
- This topic has 5 replies, 4 voices, and was last updated 8 years, 1 month ago by
baldelectrician.
February 12, 2018 at 11:26 pm #93311
baldelectrician
ParticipantHi All
I have an Indesit drier and it has a fault
It is a IDCE8540BH(uk)It has come up with a F04 code
I have taken the back off and checked the stats ( I am a qualified NICEIC / SELECT registered electrician and have the test equipment)
Both cut out thermostats have continuity, there is a thermistor – this is where I need help
What should be the reading across the thermistor?
Is there a reset possible – I really need help
Ta for the help in advance
I was referred here from Chris at the electricians forums
https://www.electriciansforums.co.uk/th … ed.136230/February 13, 2018 at 12:08 am #453901electrofix
ModeratorRe: Indesit IDCE8450 BH Drier fault
what reading are you getting across the thermistor. would expect it to be ?K ohms
there is also another thermistor at the front
assume you measured other stats out of circuit or made sure it was zero ohms ish
have no access to fault codes on this personally but other members have. its a hotpoint unit built before whirlpool took them over
also these dryers were recalled for safety has your been done ?
check here
https://safety.indesit.eu/match.jsp?lang=en_GBDave
February 13, 2018 at 12:18 am #453902baldelectrician
ParticipantRe: Indesit IDCE8450 BH Drier fault
I got it last year as a replacement for a recall one
February 13, 2018 at 12:23 am #453903electrofix
baldelectrician wrote:I got it last year as a replacement for a recall one
good !!
Have to make sure there are still lots out there. been to a few where its a wonder they have not been on fireDave
February 13, 2018 at 9:37 am #453904iadom
Don’t have error codes for this exact model but this is F04 on previous model.
F04 Pump working when should be off.
• Check security of module connector J5;
• Check connector for signs of shorting due to moisture;
• Replace module (F04 would normally be caused by a faulty
module).November 7, 2024 at 7:24 pm #453905Brianooo
ParticipantMy IDCE8450BH had fault code F08. It was an open circuit on the heater coil. I swapped the heater unit complete with the 2 thermal cut out and the thermostat. This gave me a new fault code F04. The thermostat on the new unit was not compatible with the machine. I replaced the thermostat with the thermostat from the original heater unit. Now my IDCE8450BH is running without any faults. Hope this helps.
