Re: Indesit IDE 1005 – Error code AO3
Yup, fault is time-out on drain. Can you hear the drain pump running? If yes, find the blockage – sink spigot is always a good one. If you can’t hear it running, the pump is either blocked or failed. Access from underneath is reasonably straightforward, however getting the pump to reseat and reseal properly can be an absolute swine.
Power off when investigating, or click the link below for a UKW engineer in your area if you are not sure how to proceed.
