Indesit IDF125 3 Lights flashing. Washing,End,Start/P Light
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit IDF125 3 Lights flashing. Washing,End,Start/P Light
  • #84541
    JackDeth
    I’ve been searching the net but can not find a solution for this set of lights flashing. Please anyone have an idea what the reason for this fault.
    I’ve had the bottom off and blown out drainage pipes and others hoping it was just a blockage somewhere. Thinking it may be the inlet or heater. Or does it do a cold rinse first? there is some-sort of circulation going on as when I open the door with these lights flashing I can see water coming though under the filter. Although I can here water coming in at first it seems to drain strait out and the lights flash. I did have it start to wash once but it was cold thats why I asked about cold rinse first.
    I’ve seen that the circ pump is a common thing with these but not with this flashing light combo.
    Thank you.
    I’ve just got it to start again. Sometimes the Lights come on strait away just as the water has come in but its not full when open the door. The heater is working as it got hot this time after first cycle then it drained and let the tablet in and stopped working again with the same flashing lights. I’m assuming it stopped when started to fill with water again. When I get more time I’m going to check inlet valve.
    #425974
    Re: Indesit IDF125 3 Lights flashing. Washing,End,Start/P Li
    Same as THESE
    F11 faulty electronic control module. 🙁
    #425975
    JackDeth
    Thanks for quick response Iadom. Maybe just luck at the moment. Not sure if its what I have done as you have stated control module, I tried tapping the back of the inlet as it was about to add water thinking it was maybe sticking. It now appears to be working ok. I will report back if it goes bad again. Thank you very much for the link I have saved that to bookmarks now for later.
