Indesit idf125
  • #99173
    Gareth69
    Hi, ive got a indesit idf125, it will fill then do a rinise, then at end of rinse will drain water but soon as drain starts leds 1,3 and 4 will flash and will continue to flash and empty, then stops. Is it the pressure sensor as ive taken the pressure chamber out and cleaned, blown down pressure pipe and thats seens ok i can blow and hear the water, i might buy the pressure sensor and try it, otherwise any other ideas.???
    #475262
    if it is lights 1 3 and 4 it needs a new board and thats a hotpoint only job
    Gareth69
    The lights that flash are wash, end and start button. Does this confirm your idea
    #475264
    Gareth69
    Thanks all, replaced main pcb, working great.
