indesit idf125 heat problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum indesit idf125 heat problem
  • #64895
    michaelmouse
    i have a indesit idf125 dishwasher
    i had a leak and found the heat element had burnt through the housing so i replaced it,
    sinse then the washer starts and fills, starts cycle but after about 10 mins it empties and the 2nd and fourth lights eluminate and the pause light flashes ,water does not heat .can anyone help to diagnose have tried reset but samething happens everytime i switch on.
    #358405
    Re: indesit idf125 heat problem
    2+4 is a heater fault, either your connections are wrong or more then likely the main PCB is also faulty.
    Two different PCB’s at around £60.00 ex vat but you would also need a £15 smart card and a £100 card reader to programme the PCB.
    Don’t you just love Indesit’s quality products. :rolls:
