Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit IDF125 prob
- This topic has 8 replies, 5 voices, and was last updated 12 years, 4 months ago by
peter wadsworth.
December 10, 2013 at 6:43 pm #78550
peter wadsworth
ParticipantHi all I have a 16mth old indesit IDF125 with a problem it fills up then starts its cycle for about 5sec then trips the electric switch When I turn it back on after leaving for a few minutes it will empty Any ideas please
December 10, 2013 at 7:50 pm #406070electrofix
ModeratorRe: Indesit IDF125 prob
any appliance that trip the rcd has to have an earth problem
could be a few things including the heater and leaks
December 12, 2013 at 10:27 am #406071peter wadsworth
ParticipantRe: Indesit IDF125 prob
Cheers Dave I have checked for leaks and totally dry Bit of a hoo haa to get to the bits but where is the heater
Do you think it could be the recycle pump thing
Tried it again an it fills works for 10sec then trips the mains
Thinking of now getting a new one ?????December 12, 2013 at 11:13 am #406072iadom
Dear me, earth leaks are electrical faults, there is no ‘recycle pump’, and if it is a bit of a hoo haa then I respectfully suggest you let an expert have a look at it.
December 12, 2013 at 3:16 pm #406073peter wadsworth
Srry to up set you iadom but the machine has a recirculation pump on it that could cause the problem so I have read And sorry if you did not find my humour to your taste still Christmas soon never know what Santa will bring you Over and out
December 12, 2013 at 3:51 pm #406074Martin
At 16months old your Indesit could well have problems with either the recirculating pump or the heater or both. Access isn’t too bad with the side panels and base removed to get to all. However you will need an insulation tester ideally in order to locate the earth leak.
The other option: You’ve still got time to write a note to Santa asking for a new Bosch dishwasher OR a 500 vDC Insulation Tester. 💡
December 12, 2013 at 4:09 pm #406075iadom
Don’t believe in Father Christmas, don’t believe this machine has a RE circulation pump either. It does however have a main circulation pump . 😉 both the heater and the MAIN CIRCULATION PUMP are very prone to failure on these. 😥
December 12, 2013 at 4:20 pm #406076Martin
Circulate or recirculate all the same really. It just recirculates/circulates the water round and round and round, over and over. I knew what the OP meant much if he had called it a ‘pump thingy’ or a ‘motorised pumping whatsitsname’. You are getting grumpy in your old age Jim, lighten up mate Crimbo (sorry – Christmas) is just around the corner. 😀
December 12, 2013 at 4:38 pm #406077Andy jones
You’re all far too posh. Good old wash pump for me 🙂
Sent from my iPad using Tapatalk HD -
