I have an Indesit IDF125 S which has recently started to misbehave.
It was running on an economy wash, stopped and lights 1 and 2 were flashing. The diswasher had not drained, I disconnected it and drained the waste pipe and sump of the dishwashter. The waste pipe appears to be clear.
I ran the dishwasher again empty today and experienced the same problem, although this time the diswasher had drained. I’ve seen from searching previous posts that flashing lights 1 + 2 are likely to mean a drain time out. I’m assuming that this may mean the drain pump needs replaced. But if the drain pump has failed then it seems odd that the dishwasher drained when I tested it again. Any help on possible fixes would be greatly appreciated.
