Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › indesit IDL 40
- This topic has 7 replies, 3 voices, and was last updated 20 years, 2 months ago by
TOWAN.
February 6, 2006 at 6:23 pm #15436
TOWAN
ParticipantDo not normally touch Indesit 😉 but a mates d/w has failed.
It is a IDL 40.It will do nothing,is full of water and will not start or reset.
I guess the board is faulty?
Any help welcomed! 😀February 6, 2006 at 8:05 pm #163600iadom
ModeratorRe: indesit IDL 40
Any indicator lights flashing?
February 7, 2006 at 8:55 am #163601TOWAN
ParticipantRe: indesit IDL 40
No lights flashing.
when program selected that light comes on,when reset all lights go out.
CheersFebruary 7, 2006 at 10:44 am #163602iadom
Apart from checking obvious such as individual components, wiring harness etc and getting the drain pump to run by operating the float switch, module failure could be a cause. Slight problem with the modules on these, two different ones, not interchangeable.
Instructions are……..Do not discard suspect module until fault has been confirmed as cleared. If the card is not faulty the new card may not come off the factory test cycle if the machine has other component or earth faults.
Refitting the original module may be the only way of getting the machine back to a ‘working fault position’.February 8, 2006 at 11:11 am #163603TOWAN
Cheers for info. 😀
February 8, 2006 at 8:56 pm #163604gazza57
hope reply is not too late,you say will not reset, but then all lights go out when reset? if you mean after selecting prog and than closing door all lights go out most probably circ pump, quite often when not able to select programme or reset these machines engineers presume module, qiuck check, unplug circ pump and see if it holds programme selects light, also if it has a inline heater fitted ie not in tub,earth faults can cause all sorts of spurious errors/symptons, even a megger meter is not able to confim at times .rgds gazza
February 8, 2006 at 10:00 pm #163605iadom
Good tips there gazza, Partfinder only shows, ‘in tub’ heater, does this model have tube type on later production?
February 9, 2006 at 10:13 am #163606TOWAN
Cheers for all your replys.
Turns out Indesit have been out to m/c 4 times since new and they did not want to know even thought m/c two weeks out of warranty.He has had it with Indesit.
Have got him a Bosch slimline.
Cheers again -
