INDESIT IDL 500 NO HEAT Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › INDESIT IDL 500 NO HEAT This topic has 4 replies, 3 voices, and was last updated 18 years, 4 months ago by bib. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts November 18, 2007 at 3:47 pm #32286 bibParticipant ANY IDEAS FROM MEMORY I THINK THESE HAVE A SMALL CUT OUT WHICH SCREWS IN THE BASE November 18, 2007 at 6:40 pm #234459 Penguin45Participant Re: INDESIT IDL 500 NO HEAT Screw-on safety – C00041086. Heater failure common on these, and the pcb is no great shakes either; thermistors pack in. Chris. November 18, 2007 at 10:16 pm #234460 bibParticipant Re: INDESIT IDL 500 NO HEAT THANK U QUEER THING IS IT GOES THROUGH THE PROG BUT WITH NO HEAT, CHECKED HEATER November 18, 2007 at 11:40 pm #234461 Penguin45Participant Re: INDESIT IDL 500 NO HEAT I’d be suspecting that there PCB then. Chris. November 19, 2007 at 8:09 pm #234462 adminKeymaster Check pressure switch… and NTC… From my data it’s BIT100 electronic… is it?.. you should receive error for that… If so, clean heater/fan relay or change him… and there is test program… Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
